Datenerfassung
Re: Datenerfassung
Beitragvon haegeman » So 16. Aug 2009, 12:04
http://berezintechnologies.com
dear JB 79
thank you for the proposition to help me to find a system to take all mesure at a PC .
I have just find this thing at a link giving from somebody at the forum ,can that not help us to take the mesures ,excuse me I give this link but I don't understand informatic system
thank you
luc
haegeman
Re: Datenerfassung
Beitragvon haegeman » Di 18. Aug 2009, 23:13
jb79 hat geschrieben:Hello haegeman!
Very interesting windmill!
At the moment my system is able to measure voltage, current and pulses/second. The power is calculated from voltage and current. The pulses/second will be used for the rpm value. The only thing that is missing is the windspeed, the transmission over an RS232 interface allready works and the values can be stored into a file by the PC (using hyperterminal for example).
So the next step will be to build up a schematic that would be connected to an anemometer that converts the anemometer's rotation speed (rpm) into values from 0-5V that will be feeded into the PIC microprocessor that interprets this values as windspeed values.
So if you continue to observe this thread you might get the solution you need in the future.
I will give the firmware to anybody who needs it, also the source code will be available (for adaptations).
The difficult thing is the pcb, I don't want to have it all on a hole raster pcb because there to much errors can happen during the connection of the components.
dear jb79
thank you for your proposition ,before I will say that I have no electronic formation ,I 'm just a mechanician and my english is limited ,I have good followed your work to try to take all the mesures at a PC ,so I have say ,I have a wind meter capable to connected at a pc , with a litle logitiel that I have buy with the wind meter it's not possible to charge this doument at this message the name is EPR wind rar.anemometer.
in your recherche I have see that the volt is a problem you can work just to 40 volts the alternator GINLONG for my test go to 500volt at 400rpm do you think that you have a solution ? if I ask you to help me it's because I see that you are somebody impassioned by the vertical wind turbine and that you can find a solution , if you think that you can give me a concrete solution ,I will to indemnify your work , its the sole solution for me to make mesures so if I make a transformation to the turbine I ken direct see the result better or bad.
I have receive today a mail from
[b]PAUL GELLING (gelling@sensyr.com)[We don't sell a kit, per se. We do have a device, TNG-3B, which can
adequately measure most of what you want to measure with the
addition of some simple external circuitry.
For example, RPM of the VAWT can be measured by counting
revolutions of the turbine using a simple Hall Effect switch and
a magnet. In one of our systems, we have 12 rotating rare-earth
magnets that alternate poles. Combined with a single Hall Effect
switch, we get 6 pulses/rotation (the switch only responds to
one pole).
Voltage is easy, but may require external voltage dividers.
Watts is Volts*Amps. This requires measuring current. This is
done by measuring the voltage drop across a small resistor.
Let's look at an example. If your VAWT is generating 10 amps,
and the current measuring resistor is 0.01 Ohms, the voltage
drop would be only 0.1V, but the power lost in the measurement
resistor would be 1 Watt. An instrumentation amplifier IC that
can withstand the common-mode voltage is what's needed to
turn that .1 V into something more usable. At the same time,
it would allow the measurement resistance to drop to <.01 Ohms.
Self-heating of the measurement resistance will introduce
an error term. SenSyr sells a bare PCB we call the Universal Preamp
Board that can help with making that sort of circuit.
We hope to document the readout system for our VAWT soon.
At 05:53 AM 8/18/2009, you wrote:
Dear mister .
Excusemy english he is limited .
Mister for one application for the developpement vertical turbine I need one system capable to memorised the different mesures from the power production at a PC
If it’s possible I will have the possilility to memorised ,1° the rpm from the turbine
2° the wind velocity in m/sec (I have a system windrar tto put the mesure on a PC)
3° the power in watt
4° the power in volt
5° the power in volt
To developpe a vawt I need absolutly one system capable to memorised the mesures from each transformation , my sytem with a camera is not easy and to long : http://www.youtube.com/watch?v=f-ixAoelEjM this is the litle model for test
I have no formation in informatic ,and I will find a complete system ,have you one solution ,or a solution that I can use here in Belgium with somebody with electronic formation .
Thank you
Luc Haegeman haegeman_l@skynet.be
Belgium
/b] do you understand this message for me is chinese
[img]
[/img]
Afbeelding 436.jpg (32.5 KiB) 11365-mal betrachtet
haegeman
Re: Datenerfassung
Beitragvon jb79 » Mi 19. Aug 2009, 01:00
The voltage range is no big problem, to get a higher voltage range you simple use 2 resistors that reduces the maximum needed value to 5V.
Ideal values for the maximum value are 5V*2^n values, for exmple 5V*2^7=640V. So 640V at the input will be 5V at the output. For this case the relationship beween the resistors has to be 5:635, so if the first resistance is 5kOhm the other one has to be 635kOhm. Of cause there is no real resistance availabe with this values and it would be a good idea to build up the higher value (635kOhm) by some resistors with lower values (resistors also have maximum values and 635V will exceed this limit for a single resistor.).
But with so high values the value of the resistors have to be very exact, otherwise there is a big error of the measurement.
With this strange maximum values it's not very difficult to adapt the software for the new maximum values.
My choice for the maximum values (5V, 10V, 20V and 40V) is only an example and very easy to implement into the software.
Re: Datenerfassung
Beitragvon haegeman » Do 20. Aug 2009, 23:55
dearjb79 .
I understand good that for you it's not a big problem to make the mesure with much volt ,ok for the other parameter have you also one solution ,watt or ampère.
for the rpm you have a solution for the wind speed if you give me one email adress where I can send you the logitiel from the wind rar system I send you directly my litle program ,but if you will I buy wath you say ,you can make me a list with all wath we must buy compatible with all you work before ,and than I ask you to make the corelation with th PC.I will dedomaged you for the work, but I must have concrete system with all the piece and interface to instal at the turbine ,the interface capalble to enter in the PC ,because I have no formation for informatic.
thank you
luc
haegeman
Re: Datenerfassung
Beitragvon jb79 » Do 29. Okt 2009, 00:08
So, es war in letzter Zeit recht ruhig hier, darum mal ein Update. Möchte das was derzeit funktioniert ein bißchen modifizieren, so daß man die erzielte Leistung (kWh) auch an den PC schickt. Da ich selbst kein Windrad habe will ich eine andere alternative Quelle, in meinem Fall eine 55W Solarzelle messen. Außerdem möchte ich die Umsetzung von seriell auf eine Logdatei unter Linux machen, hab nämlich in der Nähe der Solarzelle einen Eisfair-Webserver stehen, damit könnte ich Logging und grafische Aufbereitung (Webseite) gleichzeitig machen. Das reine Schreiben in eine Logdatei sollte eigentlich recht einfach sein.
Hinter der Messung will ich dann den fertigen Wandler anschließen der dann die Batterie laden soll.
Außerdem werde ich eine Möglichkeit vorsehen, mit der ich die Schaltung gegebenenfalls resettieren kann und mit der ich den Wandler auch ausschalten kann wenn die Spannung und damit die Leistung zu klein ist um sinnvoll eine Batterie zu laden.
Re: Datenerfassung
Beitragvon jb79 » So 13. Dez 2009, 12:48
So, nach laaanger Zeit jezt mal wieder ein Update.
Hab mir für einen neuen Server mit Eisfair aufgesetzt, dem ich jetzt mal beibringen möchte, die Daten der seriellen Schnittstelle einzulesen. Der steht jetzt erstmal bei mir in Wien bis die Software läuft, die übertrag ich dann auf den wirklichen Server der bei meinen Eltern steht.
Außerdem bin ich dabei, einen PIC nur mit den benötigten Teilen (Spannungs/Strommessung, serielle Schnittstelle, vermutlich nicht mal mit Display) auf eine kleine Lochrasterprint zu bauen.
Eisfair ist ein Linuxserver dem man mit diversen Paketen ziemlich alles beibringen kann (Webserver, DNS, Datenbanken, ....), derzeit kämpfe ich aber mit der Initialisierung der seriellen Schnittstelle. Wenn das mal funktioniert, dann ist das Speichern der Daten keine große Sache mehr.
Möchte auch irgendwann einem WRT54GL beibringen Daten zu speichern und regelmäßig auf den Server zu übertragen, damit wäre eine drahtlose und potenialfreie Anbindung auch über größere Strecken möglich.
Re: Datenerfassung
Beitragvon andreas » So 13. Dez 2009, 13:59
Hallo Jürgen,
so eine serielle Anbindung gabs mal für eine ältere Version von fli4l, wird aber wohl schon lange nicht mehr gepflegt. Man konnte dort die serielle aufs Netzwerk umleiten und von anderen Geräten darauf zugreifen. Wenn Dir so etwas dort über den Weg läuft, gib bitte mal Bescheid.
Re: Datenerfassung
Beitragvon andreas » Mi 16. Dez 2009, 22:30
Hallo Jürgen,
die letzten Tage ein wenig mit Kicad gespielt. Irgendwie fiel mir ein, Daß Du da mal ein Problem benannt hattest:
was ich allerdings noch suche ist, wie ich einzelne Leiterbahnen breiter machen kann, hab das zwar im Context Menü schon gefunden, funktioniert hats aber aus irgendwelchen Gründen nicht. :x
Falls Du es inzwischen noch nicht gefunden hast:
1. Menü, Formatierungen, Leiterbahnen und Vias, Leiterbahnbreite auf die gewünschte neue Breite setzen, Ok. Der eingegebene Wert wird auf irgendwelche Standards fein gerastert, stimmt aber soweit mit der Eingabe überein.
2. Kontextmenü auf dem Leiterzug (notfalls vorher mal links draufklicken, ganz sauber ist das wohl nicht), Wähle Leiterbahn-Breite. Dort sind alle schon eingegebenen Breiten einstellbar, die neue auswählen. Damit ist aber immer noch nichts passiert...
3. Wieder Kontextmenü auf Leiterbahn, nun aber Setze Breite, Editiere Segment, Leiterbahn, Netz oder ...
Damit ist es vollbracht - umständlich, geht aber.
Re: Datenerfassung
Beitragvon jb79 » Mi 16. Dez 2009, 23:16
Hallo Andreas!
Das mit den Leiterbahnstärken hab ich inzwischen ja auch im Griff, hab auch versucht eine DC/DC Wandler Platine zu zeichnen bei der alles was nicht für Leiterbahnen in Verwendung ist als Massefläche benutzt wird. Auch das funktioniert nicht so schlecht.
Re: Datenerfassung
Beitragvon CAD&Co » Sa 2. Jan 2010, 19:28
Zum Datenerfassen gibt es einen netten zuverlässigen Wasserdichten Datenlogger:
http://www.lascarelectronics.com/temper ... logger=153
32000 Messungen mit Uhrzeit ohne PC und wilder Elektronik ab 60€.
CAD&Co
